Hi folks,
Could anyone (Yani?) shed some light on the status codes please.
I'm refering to the final message one receives after running one of the possible adjustments i.e.: Line-end, clutch adjustment etc.. The format is Hex but the meaning is what I'm after... So far I couldn't find a legend or any reference...
I'm presently up against a nasty selespeed prob in a Stilo Abarth - irregular loss of entire transmission control without any stored fault. All parameters look as they should and yet - every now and again the transmission fault message comes up (in the car display) locks the box in Neutral - while the ECUScanner suggests that everything is fine. The only difference to scans under functional conditions are the affore mentioned adjustsments. Most of them will - while the fault is present - almost immediatelly result in a hex code and not being carried out - so it would be of some interest to me to understand the meaning of those numbers...
Ah, and yet another question: Does anyone knows a reasonable priced source for a ELM 327 interface? I'm located in Germany and there isn't a single one in the German bay... Next stop is China or Hong Kong, which I'm reluctant to try. There are various sources from the BIg Apple but the last time I tried this I ran into big trouble with German customs... Any suggestions welcome.
Martin
Status Codes
Re: Status Codes
About cable - I bought this one, 1 week delivery time and works fine.
http://cgi.ebay.com/ebaymotors/USB-Auto-Scanner-Interface-OBD-II-OBD2-EOBD-CAN-BUS-1-3_W0QQcmdZViewItemQQ_trkparmsZalgoQ3dSIQ26ituQ3dUCIQ252BUAQ252BFICSQ26otnQ3d12Q26poQ3dLVIQ26psQ3d63Q26clkidQ3d8983425488575221374QQ_trksidZp3907Q2em263QQcategoryZ43989QQitemZ370226495603
Re: Status Codes
Does this also work for service interval resets? As far as I can see this interface is not based on the ELM 327 chip - which is what the reset feature demands anyways. But I'd like to hear that I'm wrong here...
Martin
Martin
Re: Status Codes
Subocean,
dont worry, cable is detected as ELM 327 v1.3a and works fine, service interval reset - also works, I did it yet with this cable:
[img]http://merkur_sound.sweb.cz//v2da.jpg[/img]
Re: Status Codes
Great - and Thanx!
Martin
Martin
Re: Status Codes
I have meanwhile received those codes from somewhere else (Thanks Dirk!)
Might be of interest to other users as well.
Here are the status codes for the line-end calibration:
00 - Correct
FF - No reply from ECU
7F - Switch error 2nd gear
0b - Error caused by cosed clutch
01 - Select error 1st and 2nd gear
02 - Select error 5th and reverse gear
04 - Switch error 1st gear
06 - Switch error 3rd gear
X - Linkage error
0c - Error common conditions(?)
0d - Error adjustment clutch pin
03 - Select error 3rd and 4th gear
0e - Error clutch solenoid
07 - Select error 4th gear
0a - Error select position
09 - Switch error reverse gear
08 - Switch error 5th gear
was useful to me....
Martin
00 - Correct
X - Linkage error
Martin
