Page 1 of 2
Connection problems with ELM327
Posted: 04 Apr 2010, 11:00
by Jan_156
Hi @ all!
First, thx to Yani for the great Ecuscan software! I´ve got two interfaces, KKL and Elmcan II with ELM 327. I bought the ELM in 11/2008, the reseller said it has the chipset version 1.3a (can I prove this?). I´ve got a Stilo and tried to connect with the Elmcan, but the connection always times out, message says I have to check cable and connection settings. Cable is ok, new FTDI drivers and actual .net Framework is installed. I can connect with Scanmaster software to the ECU, but not with Multiecuscan. Do I have to change some settings in the Windows Device Manager like the KKL interface?
Greetz, Jan
Re: Connection problems with ELM327
Posted: 05 Apr 2010, 11:04
by Crombel
I had the same problem.
I got the advice from hanzs to change the baud rate in the settings of Multiecuscan to 38400 and the problem was solved.
Posted: 05 Apr 2010, 15:05
by Jan_156
Wow, that was simple. Thanks for your (and Hanzs) advice, now ELM works fine!
Posted: 08 Apr 2010, 02:25
by BR-Scan
Can you connect to the ABS and airbag ECUs with the ELM interface? Does it need to bridge the pins 1-3-7?
Posted: 08 Apr 2010, 10:33
by topogatto
BR-Scan wrote:Can you connect to the ABS and airbag ECUs with the ELM interface? Does it need to bridge the pins 1-3-7?
viewtopic.php?p=1616#p1616
Bye
Diego
Posted: 20 Apr 2010, 15:49
by luks
can`t connect with ELM. VAG works fine, but ELM not.
i try like you suggest but nothing with this.
any conception ?
Posted: 22 Apr 2010, 17:24
by ionio-zante
luks wrote:can`t connect with ELM. VAG works fine, but ELM not.
any conception ?
I've had the same problem... Despite the changes i have done to USB serial port in the Device Manager the program still gave me errors about "Connections times out"
So i have made that trick... In the USB serial port in the Device Manager i put "Bits per Second" at 38400 and the "latancy time 1". But in the Multiecuscan program at settings button i put speed 9600 bits. And with this trick it works perfect.
Posted: 22 Apr 2010, 20:07
by luks
my ELM is on real COM - RS232, there is no settings like latency time.
whatever, i will try Your trick with different values of "bits per second"
Posted: 20 Oct 2012, 09:29
by CBRider
I have problems with the installation oft the drivers on windows 7, 64 bit. If i use the ELM on windows XP the drivers instals correctly, but on windows 7 i have the problem that under system the fault code 31 pop up. Can somebody help me ?
Posted: 12 Nov 2012, 19:56
by mican
hi i have elm327 end i have problem don't connect on abs airbage dashboard but on engine works can you help my thaks
