I noticed that some Adjustment options in the CAN Setup menu are removed for Fiat Punto '03 1.2 16V (maybe for other variants too).
In version 3.6, there were two options, to set ABS System Prensent/Not Present and set Speed Sensor type.
In version 4.0 and above (at least I noticed in this version) these are gone, and only Proxy alignment is in the Adjustments.
What is the reason for this, may I ask?
Or are these options moved to some other submenu which I didn't find?
Proxy alignment options removed in new versions - Fiat Punto
https://www.puntonium.hu
