proxy alignment done without adapter,
Help! proxy alignment done without adapter, I have many control unit errors, can you fix it by trying with appropriated adapters?
Re: proxy alignment done without adapter,
This will depend on your car.
Find your vehicle here: http://www.multiecuscan.net/SupportedVehiclesList.aspx
Then look at the Body Computer entry.
You will need an ELM / OBDLink unit. If there is no [An] listed on the line then no adapter cable is required.
I have a Jeep Renegade 1.6 multijet, I have done proxy alignment after mounting navigator 6.5. when I requested the adapters 5 and 6, I did not have them and it did not make me go out of the procedure, so I went ahead but in the end it gave me many errors. my question is: doing a new alignment with the right adapters can solve the problem?
Same issue Here, there are any answers?
Problem solved using the right cable and new proxi alignement - Bless you
