Error in pneumatic pressure sensor, missing Uconnect automatic lights
iCabido
Post by iCabido »
Hi, I have 2 problems with my Jeep Renegade 2.0 Trailhawk, 2016.
1º The vehicle comes standard with a tire pressure sensor, Multiecuscan does not recognize it and if I force it and activate it with proxy alignment in the present the pressure function of the tires disappears in the frame, so I have to have it not present in Multiecuscan.
2º I have installed the light and rain sensor activating later with Multiecuscan, everything works correctly, but it does not appear in the Uconnect menu to activate or deactivate automatic lights, it can only be activated with the lever of the long lights.
Is this fixed in version 4.1 of Multiecuscan? I have version 4.0.
Please, if you can improve these two questions, it would be fantastic.
iCabido
Re: Error in pneumatic pressure sensor, missing Uconnect automatic lights
Post by iCabido »
Hello, I answer the question, the version of Multiecuscam 4.1 has repaired the aforementioned mistakes.
For my part, the question is solved.
