Diagnostic ports on fiat coupe
stephenmcc19
Post by stephenmcc19 »
Where are the diagnostic ports on the 1998 fiat coupe?.
I have the ECU port inside the wing in the engine bay, but not the other ecus, airbag etc. Can you tell me where they are please?
Stephen
Re: Diagnostic ports on fiat coupe
I think you will find the airbag ECU port under the dashboard not to far from the ECU which if I recall correctly is situated under the aircon unit on the central tunnel.
ABS is I think located near the ABS unit.
If you can't find I'll dig the manuals out and see if the wiring diags show *physical* location of the connectors.
stephenmcc19
Thanks s130.
I'll take a look later on when this snow clears, I appreciate the help.
