C1900 & C1901 fault codes
GregsGarage
Post by GregsGarage »
Hi all,
2010 Panda 4x4 1.3mjet with ABS fault codes C1900 & C1901 stored, 4x4 warning light on and 4x4 system unavailable. No faults stored in engine ECU. Latest version 3.9R1 multiplexed has no descriptions for these 2 fault codes, anyone know what they mean?
Thanks in advance, Greg
Re: C1900 & C1901 fault codes
C1900=Circuito servosterzo ad assistenza variabile cortocircuito verso negativo
C1901=Circuito sospensione posteriore destra
C1900=Power assisted steering circuit with variable short circuit to negative
C1901=Rear right suspension circuit
C1900 Steering VAPS II Circuit Loop Short To Ground
C1901 Ride Control RR Shock Actuator Circuit Failure
These are what I have as specific Fiat C-codes. Top pair come from an Italian document. Middle pair are a Google translate of the top pair. Bottom pair come from an English document. On face value the descriptions are fairly consistent.
