Alfa Romeo GIULIA
rickrd
Alfa Romeo GIULIA
Post by rickrd »
Hi , is there someone that uses Multiecuscan on the A.R. Giulia (952)?
I cant find the oil temp value, does someone know where it could be?
For sure it has to be somewhere, because it is reported on the dashboard. But where is it?
For Multiecuscan Team: are you working on new features for this car?
Chramon
Re: Alfa Romeo GIULIA
Post by Chramon »
I think Its in the "Engine" menu.
If you have a 2.0 Petrol , no support for Engine so far. Under Construction?
I have a 2.0T 200hp Petrol Giulia.
Im also looking for oil temperature values. Have you found a "functional" ELM327?
The one I bought cant connect to Can-system. Same problem described at the start page?? Have to remove a resistor?
I want to buy a "Ready-to-use" ELM327... any ideas? ;-)
rickrd
Post by rickrd »
I own a 2.2 Diesel 150 hp and the ECU is supported by Multiecuscan, but in the "Parameters" page oil temp is not shown. Maybe this value is not used by the ECU but only by the instrument panel.
I use a Konnwei Kw902 bluetooth interface that works fine with Multiecuscan and also with my smartphone.
Chramon
Post by Chramon »
Thanks for the info. I ordered a KW902 Bluetooth so I can connect to my car.
I hope the team update Multiecuscan so I can connect to ENGINE in the future. :D
