Fiat Ducato Multijet 2
Rudy
Post by Rudy »
Will multiecuscan support Fiat Ducato from 2015 - with the Euro 6 Multijet 2 engine? I believe it har the Marelli MJ8DF ecu.
Dickie831
Re: Fiat Ducato Multijet 2
Post by Dickie831 »
I using MES 3.8 - on Ducato (290) 2.3 it supports Marelli 8F3 and 9DF.. for the 2.0 and 3.0l engines it suppports no Marelli.. only Bosch
If you look at the supported vehicles list you will see that the 8DF ECU is supported on a few other vehicles, e.g. Fiat Panda 03.
This means you can try selecting the Panda 03 and it should still connect to your Ducato OK.
monette999
Post by monette999 »
My first post. Sorry
Rudi and Dickie I have a Ducato 2017 2.3L 150Hp. What ECU do I have ?
