No connection ELM 327 Wifi
Cronoblack
Post by Cronoblack »
How i can connect my ELM 327 WIFI to Multiescuscan? Because it says: Suitable interface not found! Check your cable and serial port setting" It searches the "COM port/interface".. How i connect this wifi elm 327?
THANKS!!!
tzok
Re: No connection ELM 327 Wifi
Post by tzok »
MES supports only USB and BT interfaces that create a virtual COM port in the system. ELM327 WiFi was meant for iPhone users, as they can't "pair" with non-Apple approved BT devices. Only Forscan (for Ford cars) from what I've seen has a support for ELM327 WiFi on a PC.
tolis1
Post by tolis1 »
i have elm 327 with 4.7multiecuscan,itry to connect with the adapter and everything is fine elm327wifi in settings menu(it says ok-ok-ok-ok) but no conection with car.what is wrong? please answer!thank you
