What do the numbers and letters mean when describing an airbag controller for example "TRW MY99 2F-2L-2T-I" and how can I match one of these codes up with my controller, which is TRW 51719092?
I want to make sure I select the correct one when using Multiecuscan (when my lead arrives from HK).
blackfish
Aibag control unit types
Re: Aibag control unit types
I don't know what kind of car do you have, but I tried on few Alfa Romeo's 156 made in 2000 and 2001 all JTD model with all systems that start with Allied MY 97 Airbag (...) and it worked excellent with all of them.blackfish wrote:I want to make sure I select the correct one when using Multiecuscan (when my lead arrives from HK).
blackfish
You don't have to worry too much, just try first one. If does not work try with second one…
it should work with some of them!
