2012 US Abarth
I am starting to familiarize myself with the software and was wondering if someone could confirm the PIDs. Only reason I ask is because a fellow Abarth owner is telling me our MAP sensor readings displayed by the PID labeled "Boost Pressure" is not accurate and is calculated. Only problem I see with that is MuliECSscan says the "Air Pressure" PID is calculated. Based on my Defi Boost Gauge, the "Boost Pressure" PID seems to be fairly accurate.
The following PID's are available.
Intake Pressure - Pressure measured at the intake manifold
Air Pressure - Calculated Air Pressure in Intake Manifold, calc'd by control unit based on revs & throttle angle
Boost Pressure - Pressure measured by the MAP sensor
Desired Boost Pressure - Boost Pressure calculated by the control unit
thank you
