Alfa Mito TwinAir IAW 8GSW ECU Support
martinf1964
Post by martinf1964 »
I've noticed that the Magneti Marelli IAW 8GSW (0.9) ECU used in the Mito Twinair is still not supported in the latest version of the multiecuscan software, it is however shown as a Fiat 500 option. I would like to renew my software subscription but am a bit reluctant until this ECU is supported for the Alfa Mito. Is this likely to happen with the next version release?
martinf1964
Re: Alfa Mito TwinAir IAW 8GSW ECU Support
:roll: ?
Am not in a position to comment on if/when features/functions will be supported.
However as the ECU is supported on the 500 then have you tried selecting the 500 TWIN AIR and then trying to connect to your Mito ECU? You may get a wrong ISO code but if you proceed beyond that you should be able to use MES on your Mito.
My only suggestion/warning is to be careful regarding "adjustments". Oil change should be perfectly OK to do but some others should be carefully considered.
Adepos
Post by Adepos »
martinf1964 wrote: 01 Apr 2017, 12:32 I've noticed that the Magneti Marelli IAW 8GSW (0.9) ECU used in the Mito Twinair is still not supported in the latest version of the multiecuscan software, it is however shown as a Fiat 500 option. I would like to renew my software subscription but am a bit reluctant until this ECU is supported for the Alfa Mito. Is this likely to happen with the next version release?
I have the same issue where this ECU is not supported. Can this be implemented please?
I have used the Fiat500 to access this ecu, but need to relearn phase wheel and this doesn't seem to work - maybe because vehicle is incorrect?
