TIME/DATE not correctly set on Alfa Romeo 159 SW JTDm 8V when using MES v3.5
Posted: 31 Mar 2017, 14:40
Good morning,
the firsti thing I do in order to check that things are properly working whenever I upgrade MES is a simple TIME/DATE setup using the right ELM327 interface with the green adapter.
Well, a few days ago I upgraded v3.2 -> v3.5 and tried, but date was erroneously set to 2099!!!
I then returned to v3.2, and the time/date adjustement operation was successfull, so I suppose that v3.5 is sending erroneous data to the BCM.
These are the logs I took a few days ago with v3.5 as well as with v3.2 (but also some months ago with v3.2, when all was working fine).
Thank you in advance for the analysis.
*** TIME/DATE CORRECTLY ADJUSTED USING MES v3.2 SOME MONTHS AGO ***
31/10/2016 13:47:39 (Multiecuscan 3.2)
CONNECTED TO:
Alfa Romeo 159 1.9 JTDm 8V
CAN Monitor / Vehicle Settings
EXECUTING ADJUSTMENT...
Set date and time
Old value: 144731102016
New value: 13:48 31/10/2016
COMPLETED
*** TIME/DATE UNCORRECTLY ADJUSTED AFTER UPGRADING TO MES v3.5 ***
25/03/2017 17:58:15 (Multiecuscan 3.5)
CONNECTED TO:
Set date and time
Set date and time
Old value: 175925032017
New value: 19:00 25/03/2017
COMPLETED
Set date and time
Old value: 061901122099
COMPLETED
Set date and time
COMPLETED
*** TIME/DATE CORRECTLY ADJUSTED AFTER DOWNGRADING BACK TO MES v3.2 ***
25/03/2017 19:17:37 (Multiecuscan 3.2)
CONNECTED TO:
Set date and time
Old value: 070216122099
New value: 19:18 25/03/2017
COMPLETED
Set date and time
Old value: 191825032017
New value: 20:20 25/03/2017
COMPLETED
CONNECTED TO:
Set date and time
COMPLETED
CONNECTED TO:
Set date and time
Set date and time
COMPLETED
Set date and time
COMPLETED
Set date and time
COMPLETED
CONNECTED TO:
Set date and time
COMPLETED
Set date and time
COMPLETED
