Good morning,
the firsti thing I do in order to check that things are properly working whenever I upgrade MES is a simple TIME/DATE setup using the right ELM327 interface with the green adapter.
Well, a few days ago I upgraded v3.2 -> v3.5 and tried, but date was erroneously set to 2099!!!
I then returned to v3.2, and the time/date adjustement operation was successfull, so I suppose that v3.5 is sending erroneous data to the BCM.
These are the logs I took a few days ago with v3.5 as well as with v3.2 (but also some months ago with v3.2, when all was working fine).
Thank you in advance for the analysis.
*** TIME/DATE CORRECTLY ADJUSTED USING MES v3.2 SOME MONTHS AGO ***
31/10/2016 13:47:39 (Multiecuscan 3.2)
CONNECTED TO:
Alfa Romeo 159 1.9 JTDm 8V
CAN Monitor / Vehicle Settings
EXECUTING ADJUSTMENT...
Set date and time
Old value: 144731102016
New value: 13:48 31/10/2016
COMPLETED
*** TIME/DATE UNCORRECTLY ADJUSTED AFTER UPGRADING TO MES v3.5 ***
25/03/2017 17:58:15 (Multiecuscan 3.5)
CONNECTED TO:
Set date and time
Set date and time
Old value: 175925032017
New value: 19:00 25/03/2017
COMPLETED
Set date and time
Old value: 061901122099
COMPLETED
Set date and time
COMPLETED
*** TIME/DATE CORRECTLY ADJUSTED AFTER DOWNGRADING BACK TO MES v3.2 ***
25/03/2017 19:17:37 (Multiecuscan 3.2)
CONNECTED TO:
Set date and time
Old value: 070216122099
New value: 19:18 25/03/2017
COMPLETED
Set date and time
Old value: 191825032017
New value: 20:20 25/03/2017
COMPLETED
TIME/DATE not correctly set on Alfa Romeo 159 SW JTDm 8V when using MES v3.5
Re: TIME/DATE not correctly set on Alfa Romeo 159 SW JTDm 8V when using MES v3.5
Good morning,
this post wasn't answered yet, and I'd like to know if this issue has been resolved on v3.6 or not.
I'm actually using former v3.2 because I'm afraid that this strange bug on v3.5 affecting Alfa 159 Jtdm 8V may be not alone (and this may be harmful to my car BCM), but I'd like to use new v3.6 so let me know.
Thank you in advance for your answer,
Pietro
Pietro
I have the same issue on my FIAT 500 so ya no support
Hi guys, thank god I've found this thread. I've tried changing date/time on MES 4.0, 3.8 and... its' changing with 2099.
It's driving me crazy, what a f**** crap! I will try with 3.2 version then.
Thank you!!!!!!
Thank you!!!!!!
