I have a registered version of MultiEcuScan, an ELM327 interface and i've just bought a yellow cable.
My ELM327 is working fine with MultiEcuScan for all features that don't required an additionnal cable (Engine is working fine for example). I've done an oil change, and thus I want to reset the service interval. This is the reason why i bought a yellow cable :
https://fr.aliexpress.com/item/10pcs-lo ... 0.0.h6yvVV
Unfortunately, my yellow cable doesn't work. I have the message : elm327->ecu Connection failed!
Do you think that it is not working because of my ELM327 interface? Even if my ELM327 works fine for Engine in MultiEcuScan? If I have the resistor problem with my interface (it's a cheap version), should my ELM327 work with the Engine part?
Or is it because of my yellow cable? How can I test my yellow cable?
Regards.
Simon.
