Multiecuscan 3.5 Released!
We released Multiecuscan 3.5 today with following changes:
- Added information for more ISO codes from 2015-2016 vehicles
- Added support for high speed mode of ELM327 interfaces (It is listed as ELM 327 1.3/1.4/1.4b/2.1 (High Speed) in the list of interfaces. This will switch any ELM interface to 115200 bps during the communication with modules. This trick should fix the PROXI connection problems to 500X and Renegade and will also increase a little the speed of parameter reading with ELM interfaces.)
- Support for Magneti Marelli IAW 8GMC CF5/EOBD Injection (1.4) (500)
- Support for Magneti Marelli IAW 8GSW/SDU CF5/CF5+/EOBD Injection (0.9 LPG) (500L, Panda)
- Support for Magneti Marelli IAW 8GSW CF6/EOBD Injection (0.9) (Panda)
- Support for Bosch EDC17C69 CF6/EOBD Diesel Injection (2.3) (Ducato 290)
- Support for Marelli 9DF CF6/EOBD Diesel Injection (1.3) (Egea, Tipo)
- Support for Bosch EDC17C69 CF6/EOBD Diesel Injection (1.6, 2.0) (Egea, Tipo)
- Support for 4x4 coupling control (Panda)
- Support for BOSCH ABS/ESP/TPMS (Egea, Tipo)
- Support for Bosch Airbag MY14 (500X, Renegade)
- Support for Parking control Bosch (500X, Renegade)
- Support for TRW Electric Steering (500X, Renegade)
- Support for Parking control SPM Bosch (Renegade)
- Support for Body Computer Marelli (BU) (Renegade)
- Support for CAN Setup / PROXI Alignment Procedure (BU) (Renegade)
- Support for TRW Airbag MY14 (Ducato 290)
- Support for Parking control Bosch MY14 (Ducato 290)
- Support for Tire Pressure Control (TPMS) Schrader (2/3 axle) (Ducato 290)
- Support for Bosch ABS 9 (Ducato 290)
- Support for CAN Setup / PROXI Alignment Procedure (Ducato 290)
Pandadance
Re: Multiecuscan 3.5 Released!
Post by Pandadance »
But support for Marelli 9DF CF6/EOBD Diesel Injection (1.3) (500X)? When?
This is not really the appropriate thread to raise this support request question.
However if you look carefully whilst the release info talks about the Support for Marelli 9DF CF6/EOBD Diesel Injection (1.3) (Egea, Tipo) I think you will find that this same ECU is already supported in the 500L and other vehicle models.
Until this ECU is supported as a "listed" ecu for your 500X you still have the opportunity to select the 500L / other and try to connect. In most cases I think you will be OK.
WARNING! Unless MES lists an exact Body Computer support for your car THEN DO NOT attempt to use PROXI or adjustment functions even if MES connects OK. If I am wrong in this statement then I'm sure Yani will overrule me.
gianni
Post by gianni »
Hello all I can post here because I buy the license multicuscan 3.2 and I would like to update this because I have to pay in October 2016.
It must do it and bring it a plus in relation to the 3.2 thank you for your answer since the administarteur does not answer me
Good to you
ubik
Post by ubik »
Is supported ABS/ESP 56100-65J0 calibration on Suzuki GV 2007 1.9DDiS after the replacement of unit?
Thank you
