advice needed on upgrading my current multiecuscan
birdlok
Post by birdlok »
hi there.. i am running a workshop repairing mostly on alfa's and fiat's vehicle in Malaysia. i am apparently been using a registered version of multiecuscan but as early as the 1.7 version till todate.
i am currently interested in upgrading mine to the latest version.
i am seeking advice on where to buy, which version to buy, which adaptors do i need as starters.
please advice
Re: advice needed on upgrading my current multiecuscan
Check out one of these authorised distributors:
http://www.multiecuscan.net/Distributors.aspx
Unless you go for the multiplexed interface (http://www.multiecuscan.net/OrderMultiplexed.aspx) then you will need a KKL Interface, ELM interface and a full set of EOBD adaptor cables.
In addition if you are to work on older Fiats then you will need a 3-Pin interface connector as well.
