Hi all,
I'm a new user of the software, and i have a an issue:
I'm using a ELM327 1.4 modified interface on a Lancia Delta 1.4 ecochic; when i connect the interface to the pc the dashboard gives errors of asr not available, fuel block not available and some other. I can connect to the CAN module and try to clear errors, but they still remain, otherwise all seems working fine, i have been able to reset service and to test some actuators.
After disconnection, and switching off the key all return ok in the dashboard.
Have anyone had this problem?
Thank
Dashboard errors
Re: Dashboard errors
HI!
I have the same errors with my Lancia Delta 1.4 T-Jet and 1.8 Di-Jet.
No idea why but maybe the programmer can help!?
BR
Inizio
BR
Inizio
Try cleaning the power fuse to dash so it is getting good power supply.
I also have the same problem on a bravo tjet 1.4
I think it's the interfaces because it does so even without connecting the multiecoscan software
then in alignment does not see all the control units
does anyone have a solution?
