Write IMA injector code with ELM 327 V1.4
I'm writing you about a trouble. I've a Multiecuscan licence registered. This morning I've replaced a faulty injector on my ALFA GT 1.9 MJet with a new one, but is not possible to finish the adjustment procedure with IMA code becouse this failure message appears "the procedure doesn't supported on this interface". To connect to my car I'm using a genuine ELM 327 v.1.4 interface. The connection goes well but the code injector procedure doesn't perform. Please need your help.
Re: Write IMA injector code with ELM 327 V1.4
i have the same problem, not work whit all car!
In past whit old version of MES i have do fine this operation..
https://www.facebook.com/assistenza.autronica
FES SUPPORTER
FES SUPPORTER
The injector coding must be made with a KKL interface.
Programming is not done with the ELM interface
