FIAT DOBLO 1.6 MultiJet 263 (06/2016) limited functionality
Struja
Post by Struja »
I was able to view/check about 70% of modules and functions (including reading and actuator activation) and most important for me I was able to activate OIL CHANGE function and reset SERVICE INTERVAL to 35000km even diagnostic software reports WARNING: Invalid ISO code for selected vehicle system!
Can you update support for other missing support functionality?
Thank you in advance.
Some LOG (copy-paste). If you need other logs, just let me know:
ECU ISO Code: 32 83 F8 0D 8F
18.08.2016. 15:57:29 (Multiecuscan 3.2)
CONNECTED TO:
Fiat Doblò (type 263) 1.6 Multijet 16V
Instrument Panel Marelli MY09
ECU ISO code: 32 83 F8 0D 8F
FIAT drawing number: 52042849
Hardware number: 50016820001
Hardware version: 01
Software number: 04003014122
Software version: 2002
Homologation number:
Functioning time (EEPROM): 10061
Operating time: 10065
ECU ISO Code: EC 07 B5 0D 8A
18.08.2016. 16:56:40 (Multiecuscan 3.2)
CONNECTED TO:
Continental MK60EC ABS
ECU ISO code: EC 07 B5 0D 8A
FIAT drawing number: 52026221
Hardware number: 28561130013
Hardware version: A1
Software number: XD1BAA00083
Software version: 0000
Functioning time (EEPROM): 9489
Operating time: 9529
ECU ISO Code: 00 00 60 01 14
18.08.2016. 16:54:36 (Multiecuscan 3.2)
CONNECTED TO:
Body Computer Delphi (263)
ECU ISO code: 00 00 60 01 14
FIAT drawing number: 52032154
Hardware number: 263FM1EU303
Hardware version: 03
Software number: 28484461
Software version: 0505
Homologation number: 0651
Functioning time (EEPROM): 230690
Operating time: 230697
18.08.2016. 16:53:21 (Multiecuscan 3.2)
CONNECTED TO:
CAN Info
List of configured control units :
Body Computer Node (NBC): Present
Engine Control Node (NCM): Present
Electric Steering Node (NGE): Not present
Dashboard Node (NQS): Present
Steering Wheel Controls Node (NVO): Not present
Receiver Radio (NRR): Not present
Brake System Node (NFR): Present
Info-Telematic/Convergence Node (NIT/NCV): Not present
Driver Door Node (NPG): Not present
Boot Node (NVB): Not present
Climate Control Node (NCL): Not present
Automatic Transmission Node (NCA-NCR): Not present
Steering Angle Sensor Node (NAS): Present
Parking Brake Control Node (NPB): Not present
Ceiling Node (NIM): Not present
Side Acceler./Yaw Node (NYL): Not present
Adaptive Cruise Control Node (NAC): Not present
Passenger Door Node (NPP): Not present
Driver Seat Node (NAG): Not present
Assisted Braking Node (NBA): Not present
Passive Entry Node (NPE): Not present
Steering Lock Node (NBS): Not present
Gearbox Selector Node (NSC): Not present
Passenger Seat Node (NAP): Not present
Parking Sensor Node (NSP): Not present
Engine Signals Node (NSM): Not present
Airbag Node (NAB): Present
Air Suspension Node (NMA): Not present
Roll Control Node (NRC): Not present
Self-adaptive Headlamps Node (NFA): Not present
Receiver Radio/Radio Navigator Node (NRR/RMN): Not present
CAN CONFIGURATION DATA:
4B 10 00 04 00 00 00 00 4B 10 00 04 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4B 10 00 04 00 00 00 00 09 00 00 04 00 00 00 00 4B 10 00 04 00 00 00 00 09 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00
33 36 32 36 33 31 35 30 31 38 35 4F 55 54 50 55 54 44 4A 49 54 20 15 05 05 4B 10 00 04 00 00 00 00 09 00 00 04 00 00 00 00 05 80 73 07 7B 00 00 30 A0 00 00 16 00 0F 00 00 06 0B 02 46 C0 8A 50 08 09 10 05 0C 09 00 80 00 00 00 00 00 00 54 03 44 00 00 22 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 33 00 94 00 00 00 00 82 12 37 00 00 00 00 30 00 00 00 00 00 00 00 00 01
Airbag Node (NAB)
18.08.2016. 16:51:54 (Multiecuscan 3.2)
CONNECTED TO:
Body Computer Node (NBC): EOL Ok
Engine Control Node (NCM): Ok
Dashboard Node (NQS): EOL Ok
Brake System Node (NFR): Ok
Steering Angle Sensor Node (NAS): Ok
Airbag Node (NAB): EOL Ok
18.08.2016. 16:47:56 (Multiecuscan 3.2)
CONNECTED TO:
Service Interval Reset MY09
EXECUTING ADJUSTMENT...
NEXT SERVICE KM RESET
COMPLETED
ECU ISO Code: B3 86 A4 8C 3E
18.08.2016. 16:41:06 (Multiecuscan 3.2)
CONNECTED TO:
Bosch EDC17C49 CF5+/EOBD Diesel Injection (1.6, 2.0)
ECU ISO code: B3 86 A4 8C 3E
VIN code:
FIAT drawing number: 55275093
Hardware number: 0281030837
Hardware version: 00
Software number: 1037558171
Software version: 16C3
Homologation number: 2634F
Functioning time (EEPROM): 9668
Operating time: 9716
