Oil Lamp flashing software question
Dava a
Post by Dava a »
Hello. I'm new to this board, and have joined because I have bought a Suzuki SX4 with he Fiat 1.9 diesel engine. I have the flashing oil light indicating that the oil needs changing for DPF purposes. I know this software can reset this light, but do i need to buy the registered version or will the free copy perform this? I don't mind paying for it, if it is needed, but I'd obviously rather not pay for it if the free version does this, as I will not be using it for any other functions.
Thanks for any advice
Re: Oil Lamp flashing software question
According to this: http://www.multiecuscan.net/SupportedVehiclesList.aspx
you 1.9 engine is supported and the Oil Change flag can be reset on the free version.
You will not however be able to connect to any other ECU/Module.
Also I see no Service Reset function for your vehicle.
For the engine ECU and Oil Change reset you old need a standard KKL cable with no other modifications.
Dava a
Post by Dava a »
Many thanks for the response. I have bought both a KKL VagCom type cable and an ELM 327 so hopefully one or both will do the trick!
