VDC Light on Alfa Mito
Romek
Post by Romek »
Hello I am new to this forum with limited knowledge about the use of MES.
My Mito has the VDC light on using MES does not show any fault codes so no errors to clear in ABS or Steering Modules
Therefore I had no choice but to book the car to a main Alfa Romeo dealer who clearly found codes C0051 to C0054 in the ABS computer. The dealer cleared the stored faults and put out the light. 5 days later the VDC light has come back on again. Using MES i once again cannot find the error codes to clear.
Can anyone advise if I am using MES incorrectly, or that is not able to read the ABS module ?
I have the latest version of MES and new purchased leads from GEndan a MES approved dealer distributor.
I would welcome any advise as another dealer visit is proving very expensive with no solution in sight .
Romek
Re: VDC Light on Alfa Mito
Post by Romek »
The fault turned out to be a faulty reverse light switch on the gearbox weird!!
