Fiat Fiorino 1.3 diesel
aicom73
Post by aicom73 »
¿ cual es el procedimiento para realizar el reset del servicio cambio de aceite y conseguir que se apague la luz en el cuadro instrumentos? utilizo la interface CANtieCAR y no logro apagar la luz.
Gracias por vuestra ayuda.
aicom73
Re: Fiat Fiorino 1.3 diesel
Post by aicom73 »
What is the procedure to perform the oil change service reset and get the light off in the instrument box? I use the CANtieCAR interface and I can not turn off the light. Thanks for your help.
The oil change reset is done by connecting to the ENGINE ECU (not the service computer). Go to the Adjustments Tab and the second item there is "Oil Change".
