Too many Lambda X Status parameters for AR 159 1.75TBI?
Maybe I'm wrong with reporting this, but this car/engine has 2 Lambda sensors only, so why there is 4 Lambda Status parameters? Could you please check this and amend if required
Re: Too many Lambda X Status parameters for AR 159 1.75TBI?
i have the same problem
maybe somebody answer
Might not be a bug.
It could be the ECU can support up to 4 sensors but only 2 are used in your specific car, but 4 could be used in another vehicle deployment.
Does MES display active/live data for all 4 sensors?
