I have a problem with establishing a connection to ABS module -Croma 1.9 JTD 16v 2006.Use elm 327 and adapter 1(green).The message of the program is error interface.Version of MES is 2.2 registered.When I tried with KTS Bosch everything is ok.Any ideas?
Problem with connection to ABS
Re: Problem with connection to ABS
If the connection error continues to engine control unit?
Or else can perform all connections?
If your interface set correctly?
driver
Latency Time
Com ports
driver
Latency Time
Com ports
Everythink is correct,problem is only with ABS.
