Free version and injector coding and adjusting
peteupshall
Post by peteupshall »
New to the forum and multiecuscan but familiar with other diagnostics.
Can anyone tell me if I can code and make adjustments to injectors using the FREE version of Multiecuscan on an Alfa 147 1.9JTD 16v 2002.
Also have read that I need a KKL interface to do this as the ELM interface doesn't work for this. Would prefer Elm as it will reset service interval too but injectors are the main issue at the moment.
Many thanks, in advance, for your help
Pete
Re: Free version and injector coding and adjusting
According to the supported vehicles list
then the Alfa 147 1.9JTD 16v 2002 engine ECU support is available in the free version.
You should find that the ELM interface will work OK as this engine is the same fitted to the Croma 2005 and I had no problems using the ELM interface.
