fiat brava- no ecu response
jesus-pd
Post by jesus-pd »
Hi, Im trying to diagnostic my Brava for first time.
Im using multiecuscan 2.7R1, VAG kkl, Brava 99 1.6 16v (plastic intake).
I was able to connect to ABS in a second but not to engine. So If am I right i have correctly set everything on PC, latency drivers etc. Cables stay the same? ground in the middle at both.
Im getting no ecu response. Im connected to 3pin (2pin actually) P.E.D attached on FUSE box. My ecu- MM lAW 49F. 89. I Also tried to choose 1.6 16v and lancia lybra 1.6, still no ecu response.
What could be wrong? wiring to ecu? is it possible to measure something on K-line by multimeter?
Many thanks
