Help....Ducato airbag fault after Proxi-Alignment
Nutloose
Post by Nutloose »
Ducato 2.3 2009 (Iveco engine)
ECU and BCM changed because of faulty ECU. Van starts and runs fine.
Mileage flashes.
Connect multiplexed cantiecar with 2.7 software to do a Proxi-Alignment.
Carry out alignment.. result says OK but Airbag light stays on.
Airbag fault = B104A PROXI Alignment Procedure Signal Low Present
Repeated procedure but same result.
Does anyone have an idea?
thanks
Nutloose
Nutloose
Re: Help....Ducato airbag fault after Proxi-Alignment
Post by Nutloose »
fixed....
BCM was not compatible with Airbag module.
re-fitted original BCM + ECU then do Proxi-alignment and clear airbag fault.
Swap ECU data into replacement ECU.
