I'l trying to remove the beep alarm when open/close
I'l running latest mes with bluetooth elm and yellow adapter
All other functions work fine except this
I get a security error message when submitting
I have key code but don't know where to insert it
Giulietta 120TB
Help is much appreciated
Regards
Remove alarm beep
Re: Remove alarm beep
Try first > Body Computer > F7 Adjustments > then click on Alarm mode > type Security code > select disabled > then you do not have alarm ON anymore.
Later you can only add blinkers - side indicators (when you lock and unlock the car). The procedure is the same as above.
