how to buy for fiatecuscan?
fabriziodb
Post by fabriziodb »
hi i need to buy/download fiatecuscan, can someone help me please?
Re: how to buy for fiatecuscan?
Do you really mean FiatECUScan or do you actually mean MultiECUScan?
FiatECUScan is a dead product, well out of date, that was replaced my MES.
You can buy an MES license here: http://www.multiecuscan.net/Register.aspx
Or you can get license and hardware from a distributor listed here: http://www.multiecuscan.net/Distributors.aspx
fabriziodb
thanks, I was thinking fiatecuscan was dedicated softwar for fiat, so i need mes.
do you know if after changing this part http://www.annunci.net/sites/default/fi ... /commu.jpg
a Proxi Alignment is required?
I would think probably not. If it has multiple wires in the loom/cable that plugs into it then is most probably just a simple switch unit.
fabriziodb
hi, i just installed mes 2.5, the test with elm 3.27 1.4 interface is ok.
Now before connecting with the car i would be know the correct sequence of the steps, can u help me ?
Thanks.
1) Locate your EOBD socket on the car
2) Plug interface EOBD connector into cars socket
3) Plug interface USB cable into computer
4) Start MES program
5) Select your car from the vehicle list
6) Select the required vehicle control unit
7) Turn car ignition to the on position
8) Hit the Connect
