I bought a registered version of ECU scan 2.6 and am having problems connecting with my ELM 327 interface.
I installed the drivers from FTDI site: CDM v2.12.06 WHQL Certified and have the usb ELM interface connected to 'comm port 7'. Installing the drivers got rid of the exclamation point from my device manager and in properties for comm port 7, it says "Device is working properly". However, when i go to Multiecuscan under settings and press the test button, i get the message:
"Access to the port 'COM7' is denied."
I get the same message when i try to connect to the gear box. it says "Access to the port 'COM7' is denied. Check your cable and serial port settings"
Any help on this issue would be greatly appreciated.
thank you,
S
connection problems
Re: connection problems
Hello, have you tested with port COM1 ?
