Bravo 1.6 multijet oil change reset
Hi I am new here so bear with me. I purchased the multieecuscan from Gendan off ebay to reset the service and oil change service lights on my daughter in laws Guillietta 1.6, used red obd cable and yellow interface cable, worked a treat. I now have a 2011 Bravo 1.6 which the list states only needs the red obd cable ? tried reseting the service, as with the alfa, fine, but it wont reset the change oil light. Any ideas? After executing it just returns execution failed??
Re: Bravo 1.6 multijet oil change reset
For your Bravo and the Giulietta absolutely no red adapter. !!
What ???
To make the oil reset on Bravo, no adapter is required.
And at the Giulietta depending ECU times with or without yellow Adapter
What ???
I'll use thise post for my question... I'm using registered multiecuscan software version 2.9 and OBDII usb cable and I have successfully connected to my car, Fiat bravo 1.9JTDm. I've already erased one error code in my airbag module and successfully checked situation in other modules. But I'm having troubles in service module. I can not change "date of last oil change", "distance till next service", "days till next service", "service period" and "next oil change KM reset". Whenever I try to execute change, software reports that the change has failed to execute. What am I doing wrong? Other parameters in this module were successfully changed.
Best regard and sorry for my funny english .
