after changing the dashboard lights, and I have made a couple of starts without, I reassembled everything and, with surprise, I found the airbags light on.
I must say that at this time the machine did not take leaps, etc ... it has always been in the garage stops.
Now I am bought, at www, the complete kit’s odbspecialist: license, three adapters, ELM327 v1.4, cable k-lin / wagcom and 3pins adapter.
Installed, configured with coupled 3pins + K / vag ... ok go into the engine control unit (located on the passenger side connector with yellow edges).
The ABS did not try it but now little care. Reading engine data and graphics ... ok
With the same type of configuration I thought I could also read data airbags ... but not succeed.
Now my questions are:
- There is a special unit for airbags? (I have not read any of that ... there's a kit under the tunnel but I have never read of a special connector suitable)
- The site of the multiscan about a odbkey ... I did not understand what it is ... but surely I have it all because I took the full kit ...
- ELM ... this gentleman the attack on the car with odb native (ie. Bravo, Punto ...) I thought of doing a combination 3pins with elm by the system ... but I never received any response (as with the connector k / vag you.)
Someone can tell me more?
Hoping for a Vs. answer, please send me ...
Many thanks.
Andrea
Airbag dashboard error on barchetta le 98
Ciao da Andrea
Re: Airbag dashboard error on barchetta le 98
Hello Andrea
There are at Barchetta two different airbag once the older TRW2 and yet the My97 for both you need a KKL interface or the OBDkey
The OBDkey you certainly do not get in the package because this interface for already more than 120 € cost
So with the KKL and the 3pin adapter should be able to read your airbags.
Attention !!!!! when TRW2 lot must be observed to ensure
