Empty PROXY File in BC
Davren
Post by Davren »
RE. 2003 Stilo JTD 115hp 8 valve.
Trying to connect to "CAN Setup / PROXY Alignment Procedure" with MES v2.5, I got a red warning message "Empty PROXY File in BC". I can connect to all other NODES, and everything on the car is working normally. I tried with 2 different interfaces (ELM 1.3 and 1.4), but get the same message.
Anyone any idea why I am getting this message?
spinstilaz
Re: Empty PROXY File in BC
Post by spinstilaz »
Hy Davren!
I've get the same error, and cant connect to the proxy. All other things are working fine.
I've tried connect several times and then get another error 'check connection, and port'
Now when I'm trying to connect every 2. times works.
Timmerklits
Post by Timmerklits »
I have the same problem with my alfa gt 3.2 2005.
Or it's a connection problem or it says emtpy proxy file in bc. I don't know how to solve it.
I use gendan ELM v1.3 and windows 8.1 wint multi 2.6.
Everything works only the odo is flashing always.
Timmerklits
I wonder if it really is a connectionr problem, the ELM v1.3 or so?
Will the obd key be a much better option maybe?
goforit
Post by goforit »
I have the same error (empy proxy file) trying add EPS assembled to F. Panda (169). has somebody solved it ?
goforit wrote: 25 Jun 2024, 10:00 I have the same error (empy proxy file) trying add EPS assembled to F. Panda (169). has somebody solved it ?
empty proxi file is either sign of bad connection, something wrong with CAN bus network or BCM has been replaced and not properly restored.
