2013 fiorino 1.3 MJ with dualogic errors to the DL tranny
nedro018
Post by nedro018 »
i finally rec'd my new elm 327 v 1.4 cable modified (resistor change) for fiat and tried it out yesterday here in turkey. where i bought my fiat 2013 fiorino. all worked OK except:
when i try to connect with MES v2.4 to my 2013 fiorino 1.3 MJ dualogic auto transmission module, it tells me that the "ISO code is not supported, do you want to continue, YES or NO?"
so when i say YES, i see what (seems to) look like a real/live data feed into my DL tranny. i see real numbers. real data. and the opportunity to "execute" commands to the actuators. can i? should i?
the MED pdf manual says dont do it. questions:
1) is it possible that this software wont support this 2013 transmission that's 2 years old?
2) or, can the error be disregarded?
3) can i still use the v2.4 MES program or not, for my transmission?
4) can anyone recommend another program that would support my CFC308 tranmission (not the CFC300 which is currently v2.4 MES supported) ?
5) IS THE ISO ERROR IMPORTANT? or is it just country differences for the same product?
6) is my problem because my car was purchased in turkey (a diff ISO code for this country but nonetheless equal to the CFC300 DL transmission)?
im not asking for any refunds. im asking for advice. i need SAFE ACCESS to my DL module. it is impt to me for various servicings.
thanks!
nedro018
Re: 2013 fiorino 1.3 MJ with dualogic errors to the DL trann
Post by nedro018 »
is there anyone who can help with this?
yanislav, do you frequent this site (your site)?
thanks.
