Multiecuscan 2.4 released!
We released Multiecuscan 2.4 today with the following changes:
- Added key/transponder programming function for most of vehicles after year 2000 (for all supported body computers)
- Fixed problems with remote control programming function for many models
- Changed the naming of Body Computer modules
- Fixed connection problems with TRW Airbag 2 (Ep - PROXI) on Panda <2012
- Fixed connection and error reding/clearing problems on TRW2 Airbag (Barchetta, GTV, Spider)
- Added information for more ISO codes from 2012-2014 and Brazil vehicles
- Support for Bosch ABS 5.3 (4x4) (Ducato 244)
- Support for Tire Pressure Control (TPMS) (500/500L)
- Support for CONTINENTAL Airbag MY12 (500L)
- Support for TRW MY13 ABS/ESP (500L)
- Support for CAN Setup / PROXI Alignment Procedure (500L)
- Full support for TEG Reader TRW (Electronic key) (Croma, 159, Brera)
- Full support for Body Computer Marelli (178RST2) MY04 (Palio Restyling 2, Idea)
- Full support for Body Computer Marelli (192FL) MY08 (Stilo)
- Full support for Body Computer Marelli (188FL) MY03 (Punto '03, Doblo 119/223)
- Full support for Body Computer Marelli (350) (Idea, Musa)
- Full support for Body Computer Marelli (843FL) MY06 (Idea, Musa, Ypsilon)
- Full support for Body Computer Marelli (323) (Linea, Punto International)
- Full support for Body Computer Marelli (940) (Giulietta)
- Full support for Body Computer Marelli/Finmek (843) (Ypsilon)
- Full support for Body Computer Delphi (846) (Ypsilon 2011)
- Full support for Body Computer Marelli (250) (Ducato 250)
- Full support for Body Computer Marelli (250FL) (Ducato 250 Facelift)
@lf@159
Re: Multiecuscan 2.4 released!
Post by @lf@159 »
Hi yani,
TCT gearbox control for Giulietta my14 QV is still missing
misaeru
Post by misaeru »
Hi yani,
thank you for continuing support for fiat stilo made in Brazil.
I would like to inform you that there are some cars that came out with the Delphi MT27E injection, could extend this support?
The electric power steering is used TRW (3) could extend this support?
I used this option fiat Stilo 1.9 JTD to make the process of turning angle calibration, and did not work well. The calibration was not performed.
autoalfa
Post by autoalfa »
Congratulations for the last update and especially the key programming. I am generally satisfied with the programme.I have a small workshop of group Fiat and help me very much.
eliasole
Post by eliasole »
Hi , i just receive can ti car interface with 23r6 multiecu scan in it.
Should i use this ,or update and enter serial on the 2.4 edition?
Thanks and waiting reply asap.
dinodini03
Post by dinodini03 »
I registered version 2.1, I would like to know if you can upgrade or do I have to buy back the license?
MES Licenses purchased are valid for 1 Year from date of purchase.
MES 2.1 was released on 09 Aug 2014 so if you bought a license around that time then you license will be valid for MES Version Upgrades until 9 Aug 2015.
So for the current V2.4 your current license is valid so you can upgrade from V2.1 to 2.4.
Hope this helps.
vlahovic_milos
Post by vlahovic_milos »
Hi Yani, Im interested could we programme key on Fiat Punto 2000-2007 and on Stilo 2001-2007 without prepare transponder from body dump, can we use blank megamos ID48?
Thank you in advance
