I have the software "Multiecuscan 2.3R2 Registered". Connection on my Multipla '02 BiPower/GPower using my no name OBD II diagnose interface "1A-Diag" is established successfully. It says that it is a "ELM327". I can communicate with the enigne ecu "Magneti Marelli IAE 4AF/FEF GAS Injection".
When I try to access the airbag control module "Siemens MY99 Airbag" it says "connect adapter 2/RED (or pin 3)". I now ordered a "Fiat 3 Pin OBDII OBD2 Plug Diagnose Adapter Kabel Stecker Alfa Romeo Lancia" from ebay. My problem now is, that I don't know where to connect this to. I can't locate where to plug it in.
Can anyone help me?
Thx!
Airbag Connector on Fiat Multipla
Re: Airbag Connector on Fiat Multipla
Hello Fiatmultipla
The ELM interface readout is not possible
When the red adapter (A2) is required.
Is only one KKL or OBDkey to use.
Never ELM Interface
Never ELM Interface
