Hellow. Great program, already resolved ecu check light for my 1.3 JTD idea with marea 110 jtd ecu version (Yes, i saw the wrong iso warning, but error clear works, also i was able to see most of the online params)
Wrong - Can't connect to abs.. Soldered wires to 1 and 7 pin - nothing, then 1 7 and 11 as per foto - nothing. Will try to solder only to 1 pin and cut line to pin 7.
Cable is same blue with transparent case...
Staska
