Windows 7 Home Premium 64 bit is compatible with MES 2.2
bartek.malin
Post by bartek.malin »
Hi everyone
I want buy new Windows for my Notebook. Now I have Windows Xp PRO Sp3 and everything working.
Is the operating system Windows 7 Home Premium 64 bit is compatible with MES 2.2 and ELM VIAKEN cable and V2 ?
I use other interfaces ELM 327 1.4 without resistor with Yani instruction and VAG-KKL from polish distributors.
I have notebook HP 620 6 GB RAM
Thanks for answer
Re: Windows 7 Home Premium 64 bit is compatible with MES 2.2
Yes it is.
I run MES 2.2 on:
Vista Home 32 Bit
7 Home 64 Bit
8.1 Home 64 Bit
To be more precise. Vista 32 Bit was a registered fully operational setup. I transferred this license to 8.1 64 Bit. My 7 64 Bit is running un-registered/limited mode with no problems.
I would be very surprised if it did not work on 7 & 64 Bit
PLEASE NOTE/CAUTION: Before upgrading from Xp to 7, or doing a full reinstall I suggest go through the license transfer process BEFORE doing the Win upgrade/reinstall. If you fail to do this all is not lost but you will have to go back to MES Supported to get your license reactivated. Waste of your and their time if you can avoid it.
bartek.malin
Thanks for information. After operation I'll know how it goes.
