Help connecting to ECU Fiat Punto ELX, 1998, 1.2, 85HP, 16V
Posted: 19 Jul 2014, 18:20
by gerchooo
Hi guys!
I am trying to connect to my Punto's ECU to check errors and etc. My car is: Fiat Punto ELX, 1998, 1.2, 85HP, 16V
I have these two cables that are connected to the 3pin port next to my ECU.
http://www.ebay.com/itm/New-Mini-OBD2-E ... 4d1cfd325e
http://www.ebay.com/itm/3-Pin-to-16-Pin ... 27c9ff88d0
On the other side i use laptop with bluetooth connection (Bluesoleil) to conect to the cables.
Then i use Multiecuscan (free) to try to connect to the ECU but i never manage to :(
So my question is can i use these cables to connect and if yes - what settings should i use, or i should buy KKL cable like this and then try again:
http://www.ebay.com/sch/i.html?_sacat=0 ... om&_sop=15
Thanks for your time and have a wonderful day :)
Re: Help connecting to ECU Fiat Punto ELX, 1998, 1.2, 85HP,
Posted: 19 Jul 2014, 21:02
This is your Punto, right?
Fiat Punto 85.jpg (20.14 KiB) Viewed 2590 times
There is yes you need a KKL interface
with the ELM interface, you can not do anything
Buy yourself the KKL from your link and you'll be able to connect
But you need the registered version to your engine control unit to correctly read.
