Alfa Giulietta - Cruise Control Aftermarket Activation
high-fidelty
Post by high-fidelty »
Hi, I have Multiecuscan 2.0R1 registered and an Usb Elm327 1.4 with adapter 3.
The program run perfectly and connection with CAN is succeffully.
Now, I would like to know if it is possibile to program and activate a cruise control installed aftermarket on Alfa Romeo Giulietta 1.4 Turbo Benzina 16V, assembled in year 2013.
The Cruise Control part is original and genuine Alfa, but is installed aftermarket, with correct electric scheme.
I'm not expert of this program but i see that there are these two functions:
Body --> CAN Setup / PROXI Alignment Procedure --> Cruise Control
Body --> CAN Setup / PROXI Alignment Procedure --> Cruise Control Lever
The description of both functions says:
"This function can enable/disable the functioning of cruise control."
and
"Cruise control functionality is available on some instrument clusters and body computers only!"
This last description leaves me doubtful......
I do not want to damage the car
Thanks in advace for help.
