Cruise control activation problem on Linea 1.3 diesel
Hello, I am trying to activate cruise control on my linea 1.3 mjt diesel. I'm using registered version of multiecuscan 1.7 and elm 327 1.4 (modified). I can connect to engine and try to activate cruise control under the actuators tab, but every time I click the execute button, I get "failed to execute" error message why I get this message? Please help.
Re: Cruise control activation problem on Linea 1.3 diesel
WHich verson of ELM interface do you use? USB or BT?
I use usb version of elm 1,4.A friend of mine told me to try activate from idea 1.3 mjt.Now I will try to activate selecting with idea.alfa156sarajevo wrote:WHich verson of ELM interface do you use? USB or BT?
I could activate with selecting idea 1.3 mjt instead of Linea. Now I can see cruise control ligt at gauges when I use it. After installing cables to ecu, it was working but I couldn't see the light on gauges. Now its working great.akin wrote:I use usb version of elm 1,4.A friend of mine told me to try activate from idea 1.3 mjt.Now I will try to activate selecting with idea.
Thanks for posting solution here!akin wrote:I could activate with selecting idea 1.3 mjt instead of Linea. Now I can see cruise control ligt at gauges when I use it. After installing cables to ecu, it was working but I couldn't see the light on gauges. Now its working great.akin wrote:I use usb version of elm 1,4.A friend of mine told me to try activate from idea 1.3 mjt.Now I will try to activate selecting with idea.
When someone is going to search solution with the same problem it can it find here.
