scan suzuki swift
gemantsdad
scan suzuki swift
Post by gemantsdad »
Hi,I wondered if anyone has had any success in scanning a Suzuki swift diesel,it looks identical to Fiat 500 apart from some ancillaries in slightly different locations,I have it connected up but Multiecuscan doesn't recognise it,I've tried selecting different fiat models with the same type of engine,but so far no luck,thanks in anticipation Tony.
Re: scan suzuki swift
Hello Tony
Even if the engine is in Suzuki the Fiat 500 is the same.
But can be different the motor controller!
You can times in
Multiecuscan / F11 Scan
press and you will be displayed if a readable control is available.
gemantsdad
Hi Eddy,thanks for the reply,I will get the car back and give that a try,cheers Tony
