Stilo 1.6 16V 77kW (2007).
acmn
Post by acmn »
Is Stilo 1.6 77kW engine supported by multiecuscan?
Re: Stilo 1.6 16V 77kW (2007).
acmn
Post by acmn »
s130 wrote:Please check for yourself here: http://www.multiecuscan.net/SupportedVehiclesList.aspx
Knowing the vehicle is not enough.
Magneti Marelli IAW 5NF EOBD Injection |INFO|DTC|PRM|ACT|ADJ| KL ELM OBDKey
Magneti Marelli IAW 5NF EOBD Injection (Outside EU) |INFO|DTC|PRM|ACT|ADJ| KL ELM OBDKey
Magneti Marelli IAW 5SF CF4/EOBD Injection (1.6 16V) |INFO|DTC|DTC EX|PRM|ACT|ADJ| KL ELM OBDKey
These are the options for 1.6 Stilo. But is there support for the 77kW engine?
Well, I just have to try...using my KKL/VagCom interface.
The Stilo 1.6L 16V is the 76kw/77kW engine as far as I know. Are you asking / saying you think you have some odd ball ECU in your car?
Stilo petrol engines available are:
1.2 16V 59 kW (80 hp)
1.4 16V 66 kW (90 hp) and 70 kW (95 hp)
1.6 16V 76 kW (103 hp) and 77 kW (105 hp)
1.8 16V 98 kW (133 hp)
2.4 20V 125 kW (170 hp)
acmn
Post by acmn »
s130 wrote:The Stilo 1.6L 16V is the 76kw/77kW engine as far as I know. Are you asking / saying you think you have some odd ball ECU in your car?
Yes, that's the issue. Is the 77kW engine using same ECU as 76kW engine (Magneti Marelli IAW)? Maybe not.
PM me you chassis number and I'll see what ECU / ECUs are listed for your car. I just need the model code xxx and last eight digits.
Also the fact that Yani has already supported 3 ECUs and the Stilo is a common car then I strongly suspect that the Stilo is fully covered.
You can also look at the label on your cars ECU.
acmn
Post by acmn »
Yes, the connection to ECU was created using this option:
Result: No fault codes. :D
