High Latency Problems
drum
Post by drum »
I have a registered version of MeultiEcuScan ver 1.9 however I am having trouble connecting to the CAN
Using the Port Scanner in Settings I get the following
Scanning ...
ELM 327 1.3+ interface found at port COM5, speed 38400bps
Latency Too High!!!
COMPLETED
It has been suggested that I get a yellow adapter cable which I did, but that made no difference.
I then downloaded EasyOBD to test it, and without the yellow adapter it works fine, with the yellow adapter it fails to comunicate with the car.
If I try to connect to the engine, using MultiEcuScan, that works fine.
Anybody any thoughts?
