P0685 Main relay error code
Posted: 05 Mar 2014, 18:21
During two days, I had the following error code on my on-board car computer : "faire vérifier le moteur" in french, that means in English "please check your engine car". In addition, I had an orange motor LED on the car dashboard, with no DNA and no start&stop.
For that reason, I used my ELM327 connector, with the MultiEcuScan tool, in a registered version, to check the problem. The tool shows me the following error : P0685 - Main relay - Intermittent -> see the following picture
http://hpics.li/10f59db
The error code is : P0685 ECM/PCM Power Relay Control Circuit /Open
What does it mean ? What is the problem ?
Thanks a lot in advance.
Regards
Regards
