drivers problem on windows 8.1
CBRider
Post by CBRider »
i have installed everthing on to my new pc . i have installed also the drivers for the com port. It gives me a fault (code 10) will not work
Onvoldoende quotum}
Onvoldoende virtueel geheugen of wisselbestandsquotum beschikbaar om de opgegeven bewerking te voltooien. not enough virtual memory, it is set at 3259MB.
Can somebody help me with it
Re: drivers problem on windows 8.1
Did you this read about Windows 8 on the home page?
Windows 8 note:
Multiecuscan works fine on Windows 8, but you have to install .NET Framework 3.5 (which is not installed by default). You simply have to go to Control Panel -> Add remove programs -> Add remove windows components, and install .NET Framework 3.5.
For the CANtieCAR interface you can install the same drivers as Windows 7.
DraganUS
Post by DraganUS »
Alfaeddy wrote:Hello
Windows 8 note:
I believe that in Win 8 is Con Panel - Programs and Features - Turn windows features on or off.
Add remove programs were used in windows xp.
