Faulty climate controll & start&stop system
addy75
Post by addy75 »
i've got the problem, with the climate controll and the start&stop system
After the engine stopped, the ventilation speed speed of the climate isn't adjusted by the automatic anymore.
I've to chose if to have the comfort of the automatic system and don't use the start&stop system or use s&s and lose the comfort until i turn off the car and restart it.
If it is cold and If i use the auto / full auto modus the clima sets the ventilation speed to 10/12 if the engine reaches a defined temperature (all ok). If now the s&s system turns off the engine, the ventilation speed is set to minimun 1/12 (all ok).
If i start the engine, the ventilation speed is only set back to 3/12 and will never be adjusted by the automatic until i turn off the car.
It happens when it is cold / warm outside.
Cold / Hot -> Speed 10/12 (until defined tempreature is reached) -> S&S speed 1/12 -> Engine on speed 3/12 for the hole journey, until car off (via key)
Has anybody heard of this problem, the same problem
Is it possible to reprogramm / remap the clima controll?
