Hi, I have the registered 1.8 version , this will not connect to my Alfa Mito 1.6 JTD useing a K-VAG can someone recomend the correct interface i require please.
Mick
Alfa interface req`d
Re: Alfa interface req`d
Hello mick
As in the list (supported Vehicles) of Yani is you need for the Mito an ELM interface or a OBDkey
The KKL interface you do not go on there, because the Mito with CAN is read.
And that's not the KKL
Alfaeddy is right. For Mito you need ELM or OBD key interface.
KKL interface is for older models...
